I am following the instructions to install the python API from this README, however, when running the script, I keep getting this error.
Are you using a VPN or something ? That means that the download was interrupted.
You can also manually download the file that is mentioned in the log and install it with pip.
Hi! I am not using a VPN, but I’ll try manually, thanks!
