Hello guys,
i am currently working on a semester project to track cars and bicycles and measure the distance between the two by using the xyz coordinates of the detected objects.
Now i want to create a list with all the the detected objects with their respective data like xyz values, velocity, id etc. to store them permenantly outside of the svo file. Is there a way to create a list with all the objects? I know that the date of the object list is stored in a vector but i cant figure out to make a proper list.
The plan is to store all the data and potentially teach an AI to seperate cars and bicycles better and to write an algorithm which automatically detects a “take over maneuver” of said objects.
Thank you for your help!
Myzhar
September 21, 2023, 1:44pm
2
Hi @sebbijay
You can simply create a CSV file frame-by-frame with all the information you need to save.
Thanks for the reply!
I tried the GStreamer but i cant get the CMake program to compile the gstreamer sample code from GitHub because it cant detect the gstreamer even tho it is installed.
I am mainly working with the “birds eye viewer” example und just need to get the data of the detectep objects into the csv file but i sadly couldn’t figure it out.
Myzhar
September 25, 2023, 12:21pm
4
Why GStreamer? It does not allow you to save the detected object information in a CSV file unless you write your own plugin.
What code language are you using?
Ditched the GStreamer. When i googled it together with the ZED 2 it led me to a doc page vom stereolabs explaining CSV files with gstreamer.
I am coding in c++ and trying to implement a csv solution into the bird eye viewer program.
Myzhar
September 27, 2023, 8:26am
6
OK, you can use the code here as an example:
// Copyright (c) 2020, STEREOLABS.
// All rights reserved.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
This file has been truncated. show original
We used an output file stream to save CSV line by line (std::ofstream* out_file_ptr;).
This is the code to save the header:
*sink->out_file_ptr << "TIMESTAMP,STREAM_TYPE,CAM_MODEL,GRAB_W,GRAB_H," <<
"POSE_VAL,POS_TRK_STATE,POS_X_[m],POS_Y_[m],POS_Z_[m],OR_X_[rad],OR_Y_[rad],OR_Z_[rad]," <<
"IMU_VAL,ACC_X_[m/s²],ACC_Y_[m/s²],ACC_Z_[m/s²],GYRO_X_[rad/s],GYROY_[rad/s],GYRO_Z_[rad/s]," <<
"MAG_VAL,MAG_X_[uT],MAG_Y_[uT],MAG_Z_[uT]," <<
"ENV_VAL,TEMP_[°C],PRESS_[hPa]," <<
"TEMP_VAL,TEMP_L_[°C],TEMP_R_[°C]" <<
std::endl;
and here you save all the information (IMU data in this case) line by line:
// ----> Timestamp
GstClockTime timestamp = GST_BUFFER_TIMESTAMP (buf);
*csvsink->out_file_ptr << timestamp << CSV_SEP;
// <--- Timestamp
GST_TRACE_OBJECT( csvsink, "Input buffer size %lu B", map_in.size );
GST_TRACE_OBJECT( csvsink, "GstZedSrcMeta size %lu B", sizeof(GstZedSrcMeta) );
GstZedSrcMeta* meta = (GstZedSrcMeta*)map_in.data;
// ----> Info
*csvsink->out_file_ptr << meta->info.stream_type << CSV_SEP;
*csvsink->out_file_ptr << meta->info.cam_model << CSV_SEP;
*csvsink->out_file_ptr << meta->info.grab_single_frame_width << CSV_SEP;
*csvsink->out_file_ptr << meta->info.grab_single_frame_height << CSV_SEP;
GST_LOG (" * [META] Stream type: %d", meta->info.stream_type );
GST_LOG (" * [META] Camera model: %d", meta->info.cam_model );
GST_LOG (" * [META] Grab frame size: %d x %d", meta->info.grab_single_frame_width, meta->info.grab_single_frame_height );
// <---- Info
