I’m having an issue where opening a camera via stream InitParameters.input.setFromStream(…) blocks forever regardless of the open_timeout_seconds set in the init params. Meaning that if one of my cameras is disconnected it hangs forever.
is this intended behaviour? I know the API reference says “This parameter only impacts the LIVE mode.” Is connecting via a stream not considered “LIVE” ?
Live mode means “with a camera physically connected to the host”.
When you use the Local Streaming modules, you are in “Network mode”, which has different behaviors.
