We are thinking of using 3 cameras to capture the movement of player. We are looking for high fps of 90 and wide and narrow fov
Hi @devu1402
If you plan to use standard PCs for this process, I recommend using 3x ZED 2i cameras.
You can set them to grab data at VGA resolution at 100 FPS.
ZED 2i is available in narrow and wide lens configurations. I recommend you explore the camera product page and download the datasheet to obtain details.
and if we dont want to use pc then should we get the kit?
What do you mean?
The Kits that we propose in the store are plug-and-play configurations, but they are not a mandatory requirement.
