I’m using ZED2i camera and using ZED Sensor Viewer to check if its sensors are steady.
A few weeks ago it took several minutes (5-10) to calibrate, but now there is at least one axis that still keep rotating even after half an hour or more.
In the attached screenshot it’s noticeable that I disconnected and reconnected the camera, but then the Y-axis still keep rotating.
The camera is always stationary on the floor since the beginning.
What can I do?
Moreover, if I don’t use the camera for a few minutes, it start rotating again and it doesn’t keep its steadiness.
I also tried executing "ZED Calibration.exe" --cimu but this doesn’t help.
Thank you
