I am trying to calibrate a stereo pair of ZED X One on a 2m baseline and I am really struggling to get full coverage on in the calibration software.
I have tested using an A0 board with a 13x9 90mm grid. I struggle since when I get close, I can get coverage on one side but then I am out of frame on the other camera. If I increase the FOV, getting the top corners say of the frame becomes very difficult.
How were these cameras calibrated by stereolabs when testing a 2m baseline?
Not trying to get the entire board in the FOV in one go and I am following the demo. To increase FOV, I mean taking it outside instead of being restrained to a room.
@ben-danial unfortunately, it’s hard to understand how you are trying to calibrate your rig.
Can you please record a video to show the behaviors of the calibration software?
Hi @ben-danial and @auc7us I’m very interested in keeping up to date with your findings and collaborating on this.
I’ve also been battling with a ZED X One setup as you can see here:
Next week I’ll be trying some very narrow lenses (30deg fov) on my 4k X One pair, trying to test the limits of how much accuracy I can get at longer ranges.
Hey Blake, how was going you experiment? i am wondering if buying these cameras set will fit to my needs. If you don’t mind, i would like to talk to you private to get more details.
We eventually stopped using the ZED X and have since switched to a more custom stereo solution with two standard cameras, so I don’t have any recent updates unfortunately.
The experiment with the narrow 30deg lenses on the 4K ZED X’s did show some promising signs. I was able to get the pair calibrated and the pixel size at long distances was great. The stereo depth quality seemed similar to what we were getting with a ZED 2i with narrow lens.
Hello auc7us,
I am struggling from same issue I have 2 mono cameras with baseline nearly 94 cm. The farthest I had to be from camera rig is 2.5-2.9 m in that case I am using 79*57cm cheker board. I don’t why my basline comes out to be 1.0 meter and Rms error is 16 what shall I do in this case.
