Build Error Using Stereolabs ROS2 Wrapper
Hello everyone. For a university project I am using Isaac Sim 5.0 with the Zed camera. I am following the tutorial to the letter ‘Stereolabs ROS2 Wrapper’ and I encountered this error when I ran colcon build:
Finished <<< rviz_plugin_zed_od [0.63s]
--- stderr: zed_components
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera_one/src/zed_camera_one_component_video.cpp: In member function ‘void stereolabs::ZedCameraOne::retrieveImages(bool)’:
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera_one/src/zed_camera_one_component_video.cpp:450:32: error: ‘LEFT_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_GRAY’?
  450 |         _24bitMode ? sl::VIEW::LEFT_BGR : sl::VIEW::LEFT_BGRA,
      |                                LEFT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera_one/src/zed_camera_one_component_video.cpp:450:53: error: ‘LEFT_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_GRAY’?
      |                                                     LEFT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera_one/src/zed_camera_one_component_video.cpp:462:32: error: ‘LEFT_UNRECTIFIED_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_UNRECTIFIED_GRAY’?
  462 |         _24bitMode ? sl::VIEW::LEFT_UNRECTIFIED_BGR : sl::VIEW::LEFT_UNRECTIFIED_BGRA,
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera_one/src/zed_camera_one_component_video.cpp:462:65: error: ‘LEFT_UNRECTIFIED_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_UNRECTIFIED_GRAY’?
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp: In member function ‘bool stereolabs::ZedCamera::retrieveLeftImage(bool)’:
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1494:30: error: ‘LEFT_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_GRAY’?
 1494 |       m24bitMode ? sl::VIEW::LEFT_BGR : sl::VIEW::LEFT_BGRA,
      |                              LEFT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1494:51: error: ‘LEFT_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_GRAY’?
      |                                                   LEFT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp: In member function ‘bool stereolabs::ZedCamera::retrieveLeftRawImage(bool)’:
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1512:30: error: ‘LEFT_UNRECTIFIED_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_UNRECTIFIED_GRAY’?
 1512 |       m24bitMode ? sl::VIEW::LEFT_UNRECTIFIED_BGR : sl::VIEW::LEFT_UNRECTIFIED_BGRA,
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1512:63: error: ‘LEFT_UNRECTIFIED_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘LEFT_UNRECTIFIED_GRAY’?
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp: In member function ‘bool stereolabs::ZedCamera::retrieveRightImage(bool)’:
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1529:30: error: ‘RIGHT_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘RIGHT_GRAY’?
 1529 |       m24bitMode ? sl::VIEW::RIGHT_BGR : sl::VIEW::RIGHT_BGRA,
      |                              RIGHT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1529:52: error: ‘RIGHT_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘RIGHT_GRAY’?
      |                                                    RIGHT_GRAY
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp: In member function ‘bool stereolabs::ZedCamera::retrieveRightRawImage(bool)’:
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1546:30: error: ‘RIGHT_UNRECTIFIED_BGR’ is not a member of ‘sl::VIEW’; did you mean ‘RIGHT_UNRECTIFIED_GRAY’?
 1546 |       m24bitMode ? sl::VIEW::RIGHT_UNRECTIFIED_BGR : sl::VIEW::RIGHT_UNRECTIFIED_BGRA,
/root/ros_workspace/src/zed-ros2-wrapper/zed_components/src/zed_camera/src/zed_camera_component_video_depth.cpp:1546:64: error: ‘RIGHT_UNRECTIFIED_BGRA’ is not a member of ‘sl::VIEW’; did you mean ‘RIGHT_UNRECTIFIED_GRAY’?
gmake[2]: *** [CMakeFiles/zed_camera_one_component.dir/build.make:160: CMakeFiles/zed_camera_one_component.dir/src/zed_camera_one/src/zed_camera_one_component_video.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:192: CMakeFiles/zed_camera_one_component.dir/all] Error 2
gmake[1]: *** Waiting for unfinished jobs....
In the src folder I cloned the two repositories (wrapper and example). This is the Docker file I am using:
# Use the base image ZED SDK 5.0 with CUDA 12.8 on Ubuntu 22.04
FROM stereolabs/zed:5.0-gl-devel-cuda12.8-ubuntu22.04
# Define the ROS 2 distribution
ENV ROS_DISTRO=humble
ENV LANG=C.UTF-8
ENV LC_ALL=C.UTF-8
# Install ROS 2 Humble + dependencies
RUN apt-get update -y && \
    DEBIAN_FRONTEND=noninteractive apt-get install -y tzdata curl wget gnupg lsb-release && \
    # Add the ROS 2 repository
    curl -s https://raw.githubusercontent.com/ros/rosdistro/master/ros.asc \
    | gpg --dearmor -o /usr/share/keyrings/ros-archive-keyring.gpg && \
    echo "deb [arch=$(dpkg --print-architecture) signed-by=/usr/share/keyrings/ros-archive-keyring.gpg] \
    http://packages.ros.org/ros2/ubuntu $(. /etc/os-release && echo $UBUNTU_CODENAME) main" \
    > /etc/apt/sources.list.d/ros2.list && \
    # Install ROS 2 + build dependencies
    DEBIAN_FRONTEND=noninteractive apt-get install -y \
        ros-$ROS_DISTRO-desktop-full \
        ros-$ROS_DISTRO-vision-msgs \
        ros-$ROS_DISTRO-ament-cmake-auto \
        build-essential \
        python3-rosdep \
        cmake \
        python3-colcon-common-extensions \
        usbutils \
        libusb-1.0-0-dev \
        git \
        --no-install-recommends && \
    # Clean APT cache
    rm -rf /var/lib/apt/lists/*
# Initialize rosdep and update
RUN rosdep init && \
    rosdep update
Any help would be greatly appreciated. Thank you in advance!
Please use the latest ZED SDK v5.1.1
Thanks for your reply. I hope that installing v5.1 will fix the issue.
Yes, it will fix the issue.
Meanwhile, I’m fixing the wrapper to disable features that are only available with SDDK v5.1 when using it with older versions
The colcon build works, thanks for the advice. But now I have an error in the Isaac sim terminal (I don’t know if this belongs to your domain):
[Streaming] Error: failed to create RTP Session (err:-74)
2025-11-26T10:05:43Z [367,404ms] [Error] [sl.sensor.camera.bridge.plugin] Error during zed streamer initialization 0
terminate called without an active exception
2025-11-26T10:05:44Z [0ms] [Warning] [carb.crashreporter-breakpad.plugin] [crash] A crash has occurred.
This error does not come from the ZED ROS2 Wrapper components.
Okay, I’ll look for something on the NVIDIA forum. Thanks again for your help.
