WHY IS MY ZED BOX RUNNING 3 GMSL2 CAMERAS FASTER THAN MY 64 GB AGX ORIN???
Through multiple testing instances and a large data base, I have found that my 16 GB zed box constantly runs at higher frames than my 64 GB AGX. I have no idea why this is, I am using a zed box deserializer for the AGX to read my gmsl2 cameras and its still slower.
If anyone has any ideas, or thoughts please lemme know.
e.g.
I will run 3 zed x cameras via gmsl on my 16 GB Zed Box orin nx, I will get more frames than if I run the same cameras on my 64GB AGX Orin.
I don’t know what more data I can provide, I run my code on python and have based my code on Zeds SDK and have used it quite a bit. I also have depth and custom object detection enabled(my AI model uses YOLOV12 onnx), I have resolution SVGA.
Could you be more specific on what data you would like to know that could direct your answer to our question?
The YOLO model is not optimized for the Jetson model that you are using and it is slowing down the machine.
I recommend you follow the instructions in our documentation to convert it into ONNX format and then load it in the ZED SDK pipeline to optimize the processing.
