Hello, I need help with the following, I am working with the transmission of a zed and that it receives it from unity, but I need the ip to be able to modify it from a JSON file, the problem is that I have been trying, creating a variable and assigning the value that comes from the JSON file, in addition to identifying where to modify, the problem is that it tells me that the class does not count. Can anyone support me with this issue
Thanks for reaching us out.
The ip address is set in the ZEDManager script (here).
You can retrieve the Ip from your json file and set it at this location.
I hope it helps.
Benjamin Vallon
