Hi, what is the difference between using tools like Zed Explorer and scripts for video capture and spatial mapping?
Hello and thank you for reaching out,
ZED Explorer allows you to record SVOs, from GUI or command line. You don’t need CUDA to use ZED Explorer. It’s a tool that you run as-is, without being a developer.
The script for video capture and spatial mapping are using the SDK, so they need CUDA. They may need a bit of code tuning too.
Regards
Antoine Lassagne
Senior Developer - ZED SDK
Hi, thank you very much for your reply.
So, there is no substantial difference between the information or quality regarding the captures made either with scripts or with the applications like Zed Explorer right?
Thank you.
Regards.
Indeed, the SVOs should be the same.
Antoine Lassagne
