# Zedbox Orin flash failure - QSPI Error
**URL:** <https://community.stereolabs.com/t/zedbox-orin-flash-failure-qspi-error/10461>\
**Category:** ZED Box\
**Created:** [December 1, 2025, 11:06am UTC](https://community.stereolabs.com/t/zedbox-orin-flash-failure-qspi-error/10461 "2025-12-01T11:06:55Z")\
**Showing post:** 2
**Author:** ![Myzhar](https://community.stereolabs.com/user_avatar/community.stereolabs.com/myzhar/32/11_2.png) [@Myzhar](https://community.stereolabs.com/u/Myzhar)\
**Post date:** [December 1, 2025, 11:42am UTC](https://community.stereolabs.com/t/zedbox-orin-flash-failure-qspi-error/10461/2 "2025-12-01T11:42:25Z")
Hi @hyfung
Welcome to the [Stereolabs](https://www.stereolabs.com/) community.
I recommend you try first to use this command to flash the QSPI:
`./stereolabs_bsp/Linux_for_Tegra sudo ./flash.sh --no-systemimg -c ./bootloader/generic/cfg/flash_t234_qspi.xml p3509-a02-p3767-0000 internal`
If this is successful, you can try again with the full flash script to complete the process.
_[View the full topic](https://community.stereolabs.com/t/zedbox-orin-flash-failure-qspi-error/10461)._
