Zed 2i IMU ROS topic frequency low (1.6 - 1.8 Hz)
Hi @ap07
that’s indeed the cause of your problem.
The ZED ROS Wrapper publishes data following the ROS REP105 standard, so the full TF chain must be available:
map → odom → base_link → […] → left_camera_sensor
The static TF transforms of the camera links are published by the robot_state_publisher node that is started with the ZED launch files.
If that node is not running the TF chain is broken and the node waits for valid transforms for each frame that it received with a timeout of 0.1 sec.
That’s why you are getting this low topics rate. You must install the missing package in your docker image:
apt install ros-$ROS_DISTRO-robot-state-publisher
Thanks a lot. This fixed the issue for me!!!
