my ubuntu20.04 with the same error when run ZEDfu and so on.
“AI Models”: {
“info”: [
“REID ASSOCIATION is not optimized”
“valid”: [
“MULTI CLASS ACCURATE DETECTION is optimized”,
“HUMAN BODY FAST DETECTION is optimized”,
“HUMAN BODY ACCURATE DETECTION is optimized”,
“NEURAL DEPTH is optimized”
“Camera Test”: {
“InternalDevicesCount”: 2,
“ZEDCount”: 1,
“camera”: {
“Device ID”: 0,
“Firmware”: 1523,
“Init Output”: “OK”,
“Model”: “ZED 2”,
“Serial Number”: 25492068,
“valid”: [
“Camera: ZED 2”,
“Firmware: 1523”
“resolutions”: {
“HD1080@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 1080,
“height (output)”: 1080,
“initialization”: “OK”,
“status”: true,
“width (input)”: 1920,
“width (output)”: 1920
“HD1080@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“HD2K@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 1242,
“height (output)”: 1242,
“status”: true,
“width (input)”: 2208,
“width (output)”: 2208
“HD720@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“height (input)”: 720,
“height (output)”: 720,
“status”: true,
“width (input)”: 1280,
“width (output)”: 1280
“HD720@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“HD720@60”: {
“dropCount”: -1,
“fps (input)”: 60,
“fps (output)”: 60,
“imageCount”: 502,
“status”: true,
“tearingCount”: 0,
“VGA@100”: {
“fps (input)”: 100,
“fps (output)”: 100,
“height (input)”: 376,
“height (output)”: 376,
“status”: true,
“width (input)”: 672,
“width (output)”: 672
“VGA@15”: {
“fps (input)”: 15,
“fps (output)”: 15,
“status”: true,
“VGA@30”: {
“fps (input)”: 30,
“fps (output)”: 30,
“status”: true,
“VGA@60”: {
“fps (input)”: 60,
“fps (output)”: 60,
“status”: true,
“sensors”: {
“Firmware”: 776,
“Model”: “ZED 2 (MCU)”,
“Graphics Card”: {
“deviceCount”: 1,
“deviceDriverVersion”: 11070,
“devices”: [
“arch”: “Ampere”,
“computeCapability”: “8.6”,
“cores”: 10496,
“name”: “NVIDIA GeForce RTX 3090”,
“totalMemoryBytes”: “25444024320”,
“totalMemoryMB”: 24265.3125
“initResult”: 0,
“valid”: [
“Graphics card: NVIDIA GeForce RTX 3090”
“Processor”: {
“OS”: “Ubuntu 20.04.4 LTS “,
“avxSupported”: true,
“coreCount”: “16”,
“cpu”: " 11th Gen Intel(R) Core™ i9-11900K @ 3.50GHz”,
“datetime”: “2022-08-12 10时53分31秒”,
“hyperThreading”: “1”,
“motherboard”: “Z590 UD, Gigabyte Technology Co., Ltd.”,
“ramCapacity”: “67.297542”,
“ramUsage”: “”,
“ramUsed”: “13.018812”,
“threadCount”: “32”,
“valid”: [
“Processor: 11th Gen Intel(R) Core™ i9-11900K @ 3.50GHz”,
“Motherboard: Z590 UD, Gigabyte Technology Co., Ltd.”
“USB”: {
“CorruptedFirmware”: false,
“MCUDetected”: true,
“USBList”: [
“USBMode”: 3,
“USB_path”: “/5”,
“bDescriptorType”: 1,
“bDeviceProtocol”: 1,
“bLength”: 18,
“bMaxPacketSize0”: 9,
“bNumConfigurations”: 1,
“bcdDevice”: “1.0”,
“bcdUSB”: “3.0”,
“bcdUSBClass”: 239,
“bcdUSBSubClass”: 2,
“busNumber”: 2,
“device”: “ZED2”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 0,
“idProduct”: “0xf780”,
“idVendor”: “0x2b03”
“USBMode”: 2,
“USB_path”: “/5/2”,
“bDeviceProtocol”: 0,
“bLength”: 18,
“bMaxPacketSize0”: 64,
“bcdDevice”: “3.8”,
“bcdUSB”: “2.0”,
“bcdUSBClass”: 0,
“bcdUSBSubClass”: 0,
“busNumber”: 1,
“device”: “ZED2 MCU”,
“iManufacturer”: 1,
“iProduct”: 2,
“iSerial”: 3,
“idProduct”: “0xf781”,
“USB_path”: “/5”,
“idProduct”: “0x2512”,
“idVendor”: “0x0424”
“USB_path”: “/13”,
“idProduct”: “0x5702”,
“idVendor”: “0x048d”
“USB_path”: “/12/2”,
“idProduct”: “0x0066”,
“idVendor”: “0x1ea7”
“USB_path”: “/12”,
“idProduct”: “0x0608”,
“idVendor”: “0x05e3”
“USB_path”: “/11”,
“USBMode”: 3,
“ZED Camera Module Detected”: 63360,
“ZED MCU Module Detected”: 63361,
“ZEDDetected”: true,
“valid”: [
“USB Bandwidth: OK”
“ZED SDK”: {
“CUDA Toolkit version”: “V11.7.64 -->located in /usr/local/cuda-11.7/bin/nvcc”,
“CUDA loading”: false,
“GPU Driver Version”: “Driver Version : 515.57”,
“GPU Performance”: " Performance State : P8”,
“ZED SDK Version (Diag)”: “3.7.6”,
“ZED SDK Version (RT)”: “3.7.6”,
“ai”: {
“checkAI”: true,
“cudaVersion”: 11070,
“cudnnCudartVersion”: 11060,
“cudnnVersion”: 8401,
“cudnnVersionExpected”: 8401,
“tensorVersion”: 8400
“binFiles”: [
“libsl_ai.so”,
“libsl_zed.so”,
“libsl_zed_static.a”
“resourcesFiles”: [
“neural_depth_1.3.model”,
“objects_accurate_2.2.model”,
“skeleton_accurate_2.0.model”,
“skeleton_performance_2.1.model”
“resourcesFilesExpected”: [
“objects_performance_2.2”
“valid”: [
“ZED SDK version: 3.7.6”,
“CUDA version: V11.7.64”
