Please could you tell me why my full screen side by side image is not the same on Jetson and windows with excatly the same code : Work good on MS for our 3D screen but not on jetson :
Here windows :
Here Jetson :
With the Jetson view, my 3D screen can’t make 3D render.
Thank you in advance.
Hi PrivHate,
Can you share the code you are using to display your window ?
Thanks in advance.
Hello and thanks for your answer, here the code i use :
(PS : C# dev here, working on pyhton since some days only)
cv2.namedWindow("ZedCamView",cv2.WND_PROP_FULLSCREEN)
cv2.setWindowProperty("ZedCamView",
cv2.WND_PROP_FULLSCREEN,cv2.WINDOW_FULLSCREEN)
This code work like a charm on windows.
Thank you.
Hi @PrivHate,
Thanks for sharing ! It seems indeed that OpenCV window flags have a different behavior depending on the OS.
Can you try to change cv2.namedWindow("ZedCamView",cv2.WND_PROP_FULLSCREEN)
by cv2.namedWindow("ZedCamView",cv2.WINDOW_FREERATIO)
to see if that’s the display you want ?
