@Myzhar I am writing a CPP pipeline for Zed Camera , having a close look at gst-inspect-1.0 zedsrc , I realized I cannot use Nvidia Gpu Hardware encoder as src doen not support Video/x-raw(NVMM) !!
Also are Gst Caps supported for zedsrc element ?
However further on writing a complete pipeline , my element zedsrc is not recognised in code , even when plugin is installed , where is the issue ?
#include <iostream>
#include <gst/gst.h>
static GMainLoop *loop;
struct ZedData {
GstElement *pipeline;
GstElement *source;
GstElement *timeolay;
GstElement *avc;
GstElement *enc1;
GstElement *enc2;
GstElement *enc3; // rtph264pay
GstElement *rtspsink;
static gboolean my_bus_callback (GstBus * bus, GstMessage * message, gpointer data)
// g_print ("Got %s message\n", GST_MESSAGE_TYPE_NAME (message));
switch (GST_MESSAGE_TYPE (message)) {
case GST_MESSAGE_ERROR:{
GError *err;
gchar *debug;
gst_message_parse_error (message, &err, &debug);
g_print ("Error: %s\n", err->message);
g_error_free (err);
g_free (debug);
g_main_loop_quit (loop);
break;
case GST_MESSAGE_EOS:
/* end-of-stream */
break;
default:
/* unhandled message */
break;
return TRUE; /* we want to be notified each time message is received on the bus */
int main(int argc, char **argv){
ZedData data {} ;
GstBus *bus;
GstMessage *msg;
guint bus_watch_id;
GstStateChangeReturn ret;
std::string ip;
std::string cam = "/Zed";
ip = argv[1] + cam ;
GError *error = nullptr;
gst_init_check(&argc,&argv,&error);
data.source = gst_element_factory_make("zedsrc","source");
// data.fil1 = gst_element_factory_make("capsfilter", "fil1");
data.timeolay = gst_element_factory_make("clockoverlay","timeolay");
data.avc = gst_element_factory_make("autovideconvert","avc");
data.enc1 = gst_element_factory_make("x264enc","enc1");
data.enc2 = gst_element_factory_make("h264parse","enc2");
data.enc3 = gst_element_factory_make("rtph264pay","enc3");
data.rtspsink = gst_element_factory_make("rtspclientsink","rtspsink");
data.pipeline = gst_pipeline_new("pipelineOne");
if ( ! data.pipeline || ! data.source || !data.timeolay || !data.enc1 || !data.enc2 || !data.enc3 || ! data.avc || ! data.rtspsink)
g_printerr("Not All Elements can be created\n");
/* Configure Gstreamer Element Properties */
g_object_set(data.source,"camera-resolution",2,NULL);
// caps = gst_caps_from_string("video/x-raw,width=(int)1280,height=(int)720,format=(string)BGRA,framerate=(fraction)30/1");
// g_object_set(data.fil1,"caps",caps,NULL);
g_object_set(data.timeolay, "time-format", "%D %H:%M:%S", NULL);
// gst_caps_unref(caps);
g_object_set(data.enc1,"byte-stream",true,"speed-preset",1,NULL);
g_object_set(data.rtspsink,"location","ip",NULL);
gst_bin_add_many(GST_BIN(data.pipeline),data.source,data.timeolay,data.avc,data.enc1,data.enc2,data.enc3,data.rtspsink,NULL);
if(! gst_element_link_many(data.source,data.timeolay,data.avc,data.enc1,data.enc2,data.enc3,data.rtspsink,NULL))
g_printerr("Elements could not be linked");
gst_object_unref(data.pipeline);
return -1;
ret = gst_element_set_state(data.pipeline, GST_STATE_PLAYING);
if (ret == GST_STATE_CHANGE_FAILURE) {
g_printerr("unable to set the pipeline to playing state");
return -1;
bus = gst_pipeline_get_bus(GST_PIPELINE(data.pipeline));
gst_bus_add_signal_watch(bus);
g_signal_connect(G_OBJECT(bus),"message",G_CALLBACK(my_bus_callback),NULL);
gst_object_unref(bus);
loop = g_main_loop_new (NULL,FALSE);
g_main_loop_run(loop);
/* clean up */
gst_element_set_state (data.pipeline, GST_STATE_NULL);
gst_object_unref (data.pipeline);
g_source_remove (bus_watch_id);
g_main_loop_unref (loop);
return 0;
