@purpledeer111 you are using a ZED Mini and the UVC module is not starting.
There are three possible reasons for that:
the camera is broken
the cable is broken
the cable is not correctly plugged in
The third is the most probable, even if the ZED Mini has a type C connector on camera side, it works only if plugged in the correct verse.
Please try flip it and let me know if the 2b03:f680 device is then listed with lsubs
lukas@laptop:~$ lsusb
Bus 001 Device 010: ID 13d3:3408 IMC Networks
Bus 001 Device 004: ID 0bda:57bc Realtek Semiconductor Corp. USB Camera
Bus 001 Device 015: ID 2b03:f681 STEREOLABS ZED-M HID Interface
Bus 001 Device 002: ID 8087:8001 Intel Corp. Integrated Hub
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
cable x flipped:
Bus 001 Device 016: ID 2b03:f681 STEREOLABS ZED-M HID Interface
cable y:
Bus 001 Device 017: ID 2b03:f681 STEREOLABS ZED-M HID Interface
cable y flipped:
Bus 001 Device 018: ID 2b03:f681 STEREOLABS ZED-M HID Interface
Should led next to ZED M text on camera front be on after connecting to PC? On my device the led is off all the time.
The led turns on when the camera is correctly opened by a software that uses it.
Can I ask you to run the ZED Diagnostic tool and to send the report that it generates to support@stereolabs.com?
With it, I can get more information about your system and I can better understand what can be the cause of the problem.
