I am getting an error with visual studio. Does anyone know how to solve this error?
All the files are included in the linker but I am still getting this error. I am using the x64 platform.
Check the image
Check the image
This is my CMAKE list
CMAKE_MINIMUM_REQUIRED(VERSION 2.4)
PROJECT(CMake_ZED2)
option(LINK_SHARED_ZED “Link with ZED SDK shared executable” ON)
if(NOT LINK_SHARED_ZED AND MSVC)
message(FATAL_ERROR “LINK_SHARED_ZED OFF: ZED SDK static libraries not available on Windows”)
endif()
if(COMMAND cmake_policy)
cmake_policy(SET CMP0003 OLD)
cmake_policy(SET CMP0015 OLD)
endif(COMMAND cmake_policy)
SET(EXECUTABLE_OUTPUT_PATH “.”)
SET(SPECIAL_OS_LIBS “”)
find_package(ZED 3 REQUIRED)
find_package(OpenCV REQUIRED)
find_package(GLUT REQUIRED)
find_package(GLEW REQUIRED)
find_package(OpenGL REQUIRED)
IF(NOT WIN32)
SET(SPECIAL_OS_LIBS “pthread” “X11”)
add_definitions(-Wno-write-strings -fpermissive)
ENDIF()
find_package(CUDA ${ZED_CUDA_VERSION} EXACT REQUIRED)
include_directories(${ZED_INCLUDE_DIRS})
include_directories(${OpenCV_INCLUDE_DIRS})
include_directories(${GLEW_INCLUDE_DIRS})
include_directories(${GLUT_INCLUDE_PATH})
include_directories(${CUDA_INCLUDE_DIRS})
include_directories(${CMAKE_CURRENT_SOURCE_DIR}/include)
link_directories(${ZED_LIBRARY_DIR})
link_directories(${OpenCV_LIBRARY_DIRS})
link_directories(${GLEW_LIBRARY_DIRS})
link_directories(${GLUT_LIBRARY_DIRS})
link_directories(${OpenGL_LIBRARY_DIRS})
link_directories(${CUDA_LIBRARY_DIRS})
link_directories(${CMAKE_CURRENT_SOURCE_DIR}/lib)
FILE(GLOB_RECURSE SRC_FILES src/.cpp)
FILE(GLOB_RECURSE HDR_FILES include/.hpp)
ADD_EXECUTABLE(${PROJECT_NAME} ${HDR_FILES} ${SRC_FILES})
add_definitions(-std=c++14 -O3 )
if (LINK_SHARED_ZED)
SET(ZED_LIBS ${ZED_LIBRARIES} ${CUDA_CUDA_LIBRARY} ${CUDA_CUDART_LIBRARY} ${CUDA_DEP_LIBRARIES_ZED})
else()
SET(ZED_LIBS ${ZED_STATIC_LIBRARIES} ${CUDA_CUDA_LIBRARY} ${CUDA_LIBRARY})
endif()
TARGET_LINK_LIBRARIES(${PROJECT_NAME}
${SPECIAL_OS_LIBS}
${ZED_LIBS}
${OpenCV_LIBRARIES}
${OPENGL_LIBRARIES}
${GLUT_LIBRARY}
${GLEW_LIBRARIES})
if(INSTALL_SAMPLES)
LIST(APPEND SAMPLE_LIST ${PROJECT_NAME})
SET(SAMPLE_LIST “${SAMPLE_LIST}” PARENT_SCOPE)
endif()
