The problem I’m running into is that I need the xyz coordinates for a pixel in the image in cm. I’ve tried using the point cloud measure, ie with zed.retrieve_measure(point_cloud, sl.MEASURE.XYZ). While the x and y coordinates it returns are accurate enough, the z coordinate is highly inaccurate compared to using sl.MEASURE.DEPTH.
It would be helpful if anyone knows whether using sl.MEASURE.DEPTH has a way to do this, the code I’m writing is going to be used in a real time app and I’m afraid of how much using both measures would bog down the program.
