Hello! We have a ground vehicle equipped with the ZED 2i running with ROS1 on the Jetson Nano.
The depth pointcloud given by ZED is very distorted/uneven for the floor (surfaces that are at an angle to the camera):
https://imgur.com/a/VjOXSPf
The results are exactly the same when run using the ZED_Depth_Viewer tool on the Jetson Nano. However, when using the tool on a powerful PC, the depth map quality is excellent:
https://imgur.com/JYLD03v
This difference is also observed outdoors, I could attach screenshots of those if that would help.
I understand that the computing capabilities are vastly different, but is there something that could be done to improve the quality of depth maps on the Jetson Nano? Or would you suggest some alternate strategies to make the best out of the uneven depth map that we can get?
Thank you for your time!
